Contents in Property Manager
ratnabhirud
I am trying to schedule composite wall quantity with skin thickness in the traditional L B D (Length, Bredth, Thickness) form.
Prpoerty manager doesn't allow to choose indivisual skin  thickness of  composite wall wheres  overall thickness is available in General Parameter section.
Similarly, why width, Thickness, Height and Length is generalised in General Parameter section while it is taken differently in indivisual Tool setting dialoge box.Prperty manager.jpg
AMD Ryzen 5 3600 6-Core Processor 3.59 GHz
Ram - 16.0 GB
System - Windows 10 Ultimate, 64 bit
NVEDIA GForce 8400GS
Archicad 9..., 24
Earthworm
Schedules -> Component or Surface -> Scheme settings -> Components -> Skin Thickness
Obviously Surface dependent
ArchiCAD 27 | Intel Xeon W-2225 - 4.10GHz | 32 GB RAM | GeForce RTX 3080 | Windows 10
Thank you so much for your reply!
Actually I am looking for schedule for multiple element type in one single sheet.
As per screen shot attached, figures shown in Red color are not needed. Figures shown in blue color are not needed and figures shown in purple color are also coming in double, it's taking total wall thickness wheres I need only brick wall thickness i.e. 150mm.
I am calling theese fieleds through Property manager where Building material and Components option are missing. Attaching the screen shot for it.Schedule.JPGPrperty manager 1.JPG
Ram - 16.0 GB
Archicad 9..., 24
Earthworm
Oof, your probably going to be restricted to Skin Thickness on the Inside Face / Outside Face / Air Skin Thickness & Insulation Thickness. It'll work - kinda depending on your wall composition.
