Convert Option Set Parameter to Number in Expressions
JCCARLOS91
Quick one, I think. How do I use a number from an option set parameter as a divisor to an equation?
For example, I'm trying to get the measured area (from zone) divided by total BUA (option set parameter) and multiply that by 100 to get the percentage.
I hope my query is clear.
Thank you!
John Carlos
AC25 | iMac 2019
I am not sure if you can directly.
Although you can type a number in an option set, I think it is treated as a string.
So you may need to convert this in a expression using STRTONUM ( "Text" )
Hi Barry,
I was able to reach out to a friend who assisted me in this. This the expression that we formulated to get the calculation I wanted.
Measured Area / ( ( ( STRONUM ( VILLA BUA ) * 1 m2 ) ) + ( ( STRTONUM ( TERRACE BUA ) * 1 m2 ) ) ) * 100
  • Measured Area -  automated area from the zones
  • VILLA BUA - Option Set Parameter translated to a number using "Number form String" Conversion
  • TERRACE BUA - Option Set Parameter translated to a number using "Number form String" Conversion
  • 1 m2 - To be taken form the units selection (ruler icon) to convert the Option Set Parameter into a measurable area. Specific note to click the m2 from the units selections and not to be typed in manually. Though 1 was typed in manually.
  • Remove the default " "
Hope this would help others too.
Regards,
John Carlos
John Carlos
AC25 | iMac 2019
The moral of this story is that you can do anything in Archicad if you know how
BUT
its far too complicated !!!!
Archicad 4.1 to 27 Apple Silicon
you can't build a line
Mac Studio
iPad Pro
iPhone
