2022-12-05 06:34 AM
In my model I have two slabs with different materials to simulate the difference between two pavement floors. The problem is that in a plan view the coincident line between them is represented with a dashed line instead of a continuos line.
How can I fix that without creat space between them?
Solved! Go to Solution.
2022-12-05 07:22 AM
This can be changed in the Model View Options under Construction Elements.
2022-12-07 11:21 AM
Thank you so much! You save me
