SOLVED!
Correct representation of two slab side by side
Figdor
In my model I have two slabs with different materials to simulate the difference between two pavement floors. The problem is that in a plan view the coincident line between them is represented with a dashed line instead of a continuos line.
How can I fix that without creat space between them?
1 ACCEPTED SOLUTION
Solution
This can be changed in the Model View Options under Construction Elements.
Lee Hankins
ArchiCAD 4.5 - Archicad 27UKI Apple Silicon 27.1.1
macOS Sonoma (14.2)
2 REPLIES 2
Solution
Lee Hankins
macOS Sonoma (14.2)
Figdor
Thank you so much! You save me
