Curtain Wall - not showing up in plan as in 3d??
rob2218
see attached image.
curtain wall with a double door insert not showing up properly in plan as it is showing up in 3d. Elevation is not reading properly either.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
David Maudlin
Rob:
Taking a quick look at the cw door 12, try Options > Opening Type > Side Hung Mirrored, and Options > Top Direction > 0˚. One will change the 2D Symbol, the other the opening lines (and swing direction) in 3D.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
rob2218
thanks for you input David.
Noticed you hail from DC. Where do you work?
I'll be moving there in 30 days and was looking for employment.
are you on your own or do you work for a firm??
thanks for the tip I'll try your suggestions.
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
David wrote:
Rob:
David
David,
yer instructions worked well. Only thing is that it's a bit "clunky-cumbersome" to edit the door inserts within the curtain wall. kinda feels a bit weird (until you get used to the settings) what each option setting does....but it worked.
thanks again,
Rob
i>u
Edgewater, FL!
SOFTWARE VERSION:
