Document & Visualize forum
Custom classification, omniclass and the like
hybrid
Is it possible to create a custom classification? How it's done in Revit. Our customer wants to provide his classification.
AMD R7 2700 3.8@GHz | 32 Gb RAM | SSD | GTX 1050Ti
12 REPLIES 12
Jp1138
You can create custom classifications.
https://helpcenter.graphisoft.com/user-guide/76741/
You can even download preset ones here and import them to your model:
https://graphisoft.com/downloads/Archicad/bim_data
ARCHICAD 24 SPA
Windows 10
When creating through the Archicad classifier, I will have to manually change everything again manually each time. It is necessary that he read from a .txt file or .xml
Already preinstalled or according to your link do not suit us at allСнимок экрана 2021-09-07 230422.png
This is the second time I am writing this answer. In the new (stupid) forum, for some reason, the answers disappear after editing them.
And so, when creating the Archicad Classifier, the ability to change at the request of the customer will be very difficult, since he provides us with a .txt or .xml file that they worked (used) in revit. Instead of just loading this file, I will have to redo everything. And this is very time consuming.
Снимок экрана 2021-09-07 231424.pngСнимок экрана 2021-09-07 230422.pngСнимок экрана 2021-09-07 214154.png
hybrid
Already preinstalled or according to your link do not suit us at allСнимок экрана 2021-09-07 231424.pngСнимок экрана 2021-09-07 230422.png
hybrid
P.S Классификаторы по ссылке вообще не подходят нам.
I would open the TXT file the client sent me, and also open an Archicad classification XML files.
Then, I would see if there can be some relatively easy way to convert the data in the TXT file into the XML format.
Laszlo Nagy, Lead Moderator, Community Admin
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, NVidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
do you plan to add such functionality in the future?
I am not the right person to ask this question.
You can make a wish for this feature if it is important to you, we can vote on it and if it gets enough support, we can submit it to GRAPHISOFT for consideration.
If you do make a wish, please post its link in this thread.
bouhmidage
Unfortunately, this is impossible... Due to the nature of Archicad xml file structure.
Even if youbopen revit xml file in excel to map it to Archicad xml structure, you cannot ewport excel sheet as xml, because Archicad xml mapping uses list of list mapping, not supported by excel.
Txt format can't be read by Archicad,
The only way i found so far is to manually create your classification, like i did few months ago, much faster than waqting time on googelling
Archicad 23
Windows 10 professional
I think that it is not impossible using GDL.
My idea would be to write a GDL script to read the TXT file, interpret what is happening (e.g. the next line in the TXT file is a level 1/2/3/4 item, or it is the Child entry of the item in the previous line, or it is a new item in a higher level (e.g. after five level 4 items, the next line in the TXT file is a level 3 item), and based on that regenerate the same structure in XML, but following the formatting that Archicad requires.
I would be using the TXT I/O GDL extension to read from the TXT file,  and the XML I/O GDL extension to write the XML file.
I definitely do not have the time to do it, but if I did something like this, this is the approach I would take.
Here is another approach using Excel in another thread:
https://community.graphisoft.com/t5/Document-Visualize-forum/Custom-classification-creation/m-p/3051...
Or you could write a script to parse the Revit Assembly Code text file and make an XML from it. But yes, the method in the other thread could be followed as inspiration.
--- stefan boeykens --- architect-engineer-musician ---
ARCHICAD25/Revit2020/Rhino6/Unity2020/Solibri
MBP2019:i9Octo2.4GHz32GBVega20/BigSur+Win10
ARCHICAD-user since 1998
