Document & Visualize forum
Custom stair treads not showing correctly in 2D symbol
B_E_A_T_
I've created a special stair, using custom stair treads and risers (draw with morph, save as custom object (tread/riser)). It looks perfect in 3D, but the custom treads and (long) risers don't show up in de 2D representation symbol.
I have already added "PROJECT2 3, 270, 2" to the 2D script of the elements, but that did not make any difference. Oddly enough, the other custom risers (L-shaped) do show up correctly... The adjusted landings also show correctly, but these were changed using the stair tool edit mode, not replaced by custom objects...
Any tips?
(òÓ,)_\,,/
www.studiov2.be
Archicad 23/24/25 BE
Rhino/Grasshopper for Mac
I have received some info from GS HQ related to this issue.
You problem probably stems from the fact that your custom Treads/Risers are outside the Floor Plan boundaries of the original Stair and this is the reason why those customs Treads/Risers are not displayed.
Try to model the Stair so it is as wide as the planned custom Treads/Risers. This way all the custom geometry will be within the original Stair boundaries and then the 2D display of those Treads/Risers should be correct.
Laszlo Nagy, Lead Moderator, Community Admin
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, Nvidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
B_E_A_T_
Thank you - this should work!
(òÓ,)_\,,/
www.studiov2.be
Labels
