Visualization
Dark glass and "dirty" walls
Hello,
This is one of my first render in ArchiCAD and i've got 2 problems.
The first (in blue) is about my glass which appears sometimes really dark/black
The second (in red) is the wall which appears like dirty
Could someone tell me how to fix that ? Thank you very much
(I never changed the glass surface setting)
5 REPLIES 5
Eduardo Rolon
If I remember correctly general Options add more ray depth.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
David Maudlin
sachals:
For the 1st issue, Ray Threshold, Ray Depth and Reflection Depth play a role, in the Help files see: User Interface Reference > Dialog Boxes > Detailed CineRender Settings > General Options (CineRender). Maybe this will also help with the 2nd problem.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC27 USA • iMac 27" 4.0GHz Quad-core i7 OSX11 | 24 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
Thank you for your answers ! I just changed my signature and it works better when I change Ray Threshold, Ray Depth and Reflection Depth
David Maudlin
sachals:
Glad that worked, thanks for posting back and adding the signature.
David
What should I do, when I am not able to change anything (options are blocked).
