2022-12-11 06:50 AM
I have installed the newest version of the unreal datasmith exporter in order to link Archicad project to twinmotion. Datasmith is not showing in Archicad window palettes as it should. What can I do?
Solved! Go to Solution.
2022-12-11 07:29 AM - edited 2022-12-12 12:26 AM
Which version have you installed (5.0.3 or 5.1)? If you installed from this page, it is the wrong one: https://www.unrealengine.com/en-US/datasmith/plugins
You should be installing 5.0.3 from this page:
https://www.twinmotion.com/plugins/Archicad
This will probably change soon (a new TM preview version will be relased soon, so probably there'll be a new plugin as well), but for now please use the link from the twinmotion page and not the unreal one.
2022-12-11 08:13 AM
I have tried both, and neither one is working
2022-12-11 08:54 AM
do you see the plugin in your addon manager? could you provide some screenshots?
2023-01-16 01:15 PM
Hi! have the same problem, and I don't see the plugin in the addon manager.
2023-01-16 01:34 PM
Okay I was dumb, I forgot to close and then re-open the archicad file, now it has appeared
