Document & Visualize forum
Deciduous trees 24 orientation
Dave Brach
I am trying to rotate the deciduous trees 24 object exactly how I want it, but there seems to be some kind of automatic orientation built into the object where it snaps to certain angles.  Is there a way to control this or turn it off?  (I am actually trying to place 2 objects on top of each other at 90°, but can't get it to work)
Dave Brach/architect
Salt Lake City USA
www.brachdesign.com
AC24 MBP OS Catalina 10.15.7
2.6 GHz 6core intel core i7 16 GB RAM
Radeon Pro 555X 4096 MB
Intel UHD Graphics 630 1536 MB
Those 'billboard' type trees are set to rotate to face the camera.
So every time you re-build in 3D or do a render (or fly-through), the object will turn automatically to face the camera.
So you should only ever need to place one.
They won't turn as you rotate in 3D - you have to rebuild and regenerate the view.
Versions 6.5 to 25
1 REPLY 1
Versions 6.5 to 25
Labels
