Interesting.
If you set your 'existing elements' to 'override', then the demolished wall hole shows.
If you set your 'existing elements' to 'show', then the demolished hole disappears.
I think the logic here is that the demolished window is filled with a 'new' wall - you have no control over this that I can see.
So you are actually seeing a new wall in the existing one - which makes sense.
When 'new' is set to show and 'existing' is set to show, then the walls are both displayed the same and so blend together with no join.
When either or both are set to override, then their display is being altered and the opening will show.
No matter what settings I make to the new and existing overrides, the opening will always show - even if they all match each other or I turn the overrides off with the check box.
You can set the 'new' line colour to white, but of course that will affect all new elements.
So the only solution I see is to set your new and existing overrides to both 'show'.
