2014-12-04 02:03 PM
2014-12-04 02:22 PM
2014-12-06 08:41 PM
2014-12-06 09:00 PM
laszlonagy wrote:You can if you create a new floor plan view and change it to a larger scale.
You still will not be able to make enlarged Floor Plan details that are live. Those will still be static and need to be updated.
2014-12-06 10:37 PM
2014-12-07 06:04 PM
laszlonagy wrote:I know you do but I just wanted to make sure others do to.
Yes, I know this is a solution, but not as elegant as the "other" one.
laszlonagy wrote:
Would be nice to have live Details/Worksheets in ArchiCAD too.
2014-12-07 11:21 PM
Barry wrote:Oh, OK, sometimes I have to remember that something that is "addressed to me" is not necessarily addressed to me.laszlonagy wrote:I know you do but I just wanted to make sure others do to.
2014-12-08 07:56 AM
2014-12-08 11:41 PM
2014-12-09 12:25 AM
2014-12-11 03:02 PM
Barry wrote:+1
My wish is that details and worksheets were live with the model with the option to change them to 'Drawing' just like we can now with sections and elevations (that's why I use sections for details).
2014-12-12 10:33 AM
Barry wrote:The way that this works in Revit is that the model is always live (sections, details [plan or section]). Any "annotation" that you put in those views (including detail items like a 2x member for example), stays there as the model updates live. What is great about that is that you can use the sections/details to check the design and back and forth. Make a change in the model, check the detail and modify as needed or detail in a different way as a response to the model.
2014-12-12 11:30 AM
2014-12-13 01:27 AM
2014-12-14 11:50 AM
DGSketcher wrote:+1
I don't see the benefit of live details. The level of detail in the model is usually far from being accurate enough for say a 1:5 detail with fixings, membranes and complex manufacturers profiles. In my workflow I use the detail tool to create the basic line work, adapt it to suit and if necessary use the trace option to check any changes in the live source.
I agree it would be useful to keep a detail live while the drawing set is being developed but I would definitely want to be able to break the link once additional 2D information is added.
2019-10-31 06:38 PM
DGSketcher wrote:-1
2019-11-01 02:37 AM
2019-11-03 06:47 AM
2019-11-04 06:31 PM
2019-11-04 07:22 PM
