Dimension Chain ?
I have just installed AC22 on a new computer. On my old computer, when dimensioning, if I select a wall (sets a point at each side of the wall), I then get to select another point or wall before placing the dimension location. On my new computer, I select the wall and the dimension is immediately placed where I clicked to select the wall. I cannot find any setting to change this behavior. Can someone point me in the right direction to fix this?
2 REPLIES 2
David Maudlin
Kris:
In the Dimensions settings, check the Dimension Type. It sounds like it is not set to Linear Method. Same setting under Construction Method in the Info Box.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC27 USA • iMac 27" 4.0GHz Quad-core i7 OSX11 | 24 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
There is a new button in the settings that immediately places just the wall thickness.
I am not in front of Archicad at the moment so I can’t paste an image.
It is in the geometry method settings an is called ‘single click thickness’.
Hopefully this link will show you the correct page in the manual.
https://helpcenter.graphisoft.com/user-guide/77033/
Learn and get certified!
