Dimension pointer lengths.....they got longer in v22
Any one know a way to adjust the length that the pointer arm will "pop up". Previously (v21) it was a relatively short "arm" but I thought it should pop up sooner, now that arm length is even longer. Any adjustments to be made?
1 REPLY 1
If you mean the extension to the witness lines, you do not have specific control over that length.
It is set based on the size of the markers.
The marker size is in printable page size where as the witness line is in model units..
