2016-10-0806:17 PM - last edited on 2023-05-1903:53 PM by Gordana Radonic
Hello.
I am searching for the setting which determines the dimension text to automatically move outside the dimension space, once it gets bigger than the dimension space. Does anybody have a clue where it is? I am trying to deactivate it.
Thank you.
In AC20: Dimension Tool Settings > Dimension Details > Dimension Text Placement Method: Centered. Your signature indicates AC16, I don't know which version this was introduced.
David Maudlin / Architect www.davidmaudlin.com Digital Architecture AC27 USA • iMac 27" 4.0GHz Quad-core i7 OSX11 | 24 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
Thank you very much for your answer.
Archicad 16 does not have this setting, nor does Archicad 18, as I found out. I don't know about Archicad 19.
But thank you again.
