OK if you are now using the 'DIN' scheme for the dimensions in your views then you need to go into OPTIONS menu > Project Preferences > Dimensions and change the settings to what you want for that scheme.
Or set up any other scheme or create your own new one to have the settings you want.
Then make sure you use that scheme in your views.
I usually leave all the default schemes as they are and create my own new ones.
