Document & Visualize forum
Dimensioning on a section
Dontknow
Hi all, is it possible to make a dimensioning on a section including a dash-dot dimension line like the example below?
Architectural construction designer, draftsman, modeller
ArchiCAD 24 (5000, NED EDU).
Windows 10 - 64 bit, Intel Core i7-2600, 12 GB, NVidia GeForce GT640 2 GB Passive.
Dontknow
Meanwhile I found out its the witness line set to 'Dynamic Height'.
Looks like you can't set the line type.
Dimensions have no control over the line type.
Versions 6.5 to 25
