2021-11-16 12:48 PM - last edited on 2022-10-04 02:03 PM by Oleksandra Vakariuk
Hello AC community,
We have created a very simple section through a building.
The saved model view (image can be seen below) we have included a string dimension for the floors / ceilings etc. When placing the view on the layout the dimension arrows aren't appearing correctly and on some sections disappear altogether.
Has anyone seen this bug or have any suggestions / work around to get the arrows & dimensions appearing correctly.
Many thanks for reading.
Chris S
CSP Architects
Archicad 25 (4013 UKI FULL)
Windows 10 Pro
Processor Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz 4.00 GHz
RAM 32.0 GB
Solved! Go to Solution.
2021-11-17 12:41 PM
Hi Noemi,
I think it is a different topic... we have had a solution for our particular query thankfully.
Arrow size was the problem as described in the article below.
2021-11-17 08:10 AM
Chris, can you check if this is what you experience? https://community.graphisoft.com/t5/Teamwork-articles/Dimensions-Display-Inconsistently-Among-Teamwo...
Might give you useful tips how to workaround the problem.
Noémi Balogh
Community Expert, Admin
2021-11-17 11:47 AM
Thanks for the reply Noemi really appreciated.
I have tried runnning through the options on th article with no joy i'm afraid. There is another article linked below which suggests there is a known bug which the developers are aware off the issue.
I have contacted Graphisoft support as it is a big problem for us.
Thanks again.
2021-11-17 12:41 PM
Hi Noemi,
