2020-03-11 08:00 AM
2020-06-22 06:09 AM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-07-09 06:45 AM
2020-07-15 12:35 AM
Minh Nguyen
GRAPHISOFT
2020-08-10 09:21 AM
2020-10-15 06:24 AM
2021-02-16 06:42 AM
2021-02-17 12:11 AM
Minh Nguyen
GRAPHISOFT
2021-03-08 04:53 PM
mnguyen wrote:Oh, I wish this were true! I'm running AC24 5000 USA FULL, and my dimensions just "jumped" as Chris had initially described. The jump was exactly 1.25" in a few dimension strings. The 4 1/4" dimensions previously read as 5 1/2" and the 2 1/4" dimensions previously read as 3 1/2". The only way to fix them is to select them, go into the settings and then press OK. This is not OK. When this happens, I lose faith in the dimension strings on other drawings within my drawing set and it takes time (time that I don't have) to open each view, select all of the dimensions and then press OK.
Unfortunately, due to technical difficulties, the fix for this bug could only be made for Archicad 24 in Update 2 only. To get rid of this issue, we need to upgrade to Archicad 24.
Best regards,
Minh
2021-03-09 02:01 AM
jffgrffn wrote:Hello,
See image at link below.
https://www.dropbox.com/s/ona9vkcshs3agwg/Jump.png?dl=0
I hope that this gets fixed ASAP. It's gone on far too long.![]()
Minh Nguyen
GRAPHISOFT
2021-03-09 03:57 AM
2021-03-09 04:36 AM
2021-03-09 06:16 AM
2021-03-10 02:44 AM
Minh Nguyen
GRAPHISOFT
2021-08-13 05:08 AM
2021-08-17 07:13 AM
Minh Nguyen
GRAPHISOFT
2021-10-20 01:08 PM
Hi Minh,
Shortly after sending my last inquiry, the project was taken out of BIMcloud and saved as a standalone PLN. Well, today upon publishing a PDF, I noticed that some of the dimensions (which were placed months ago and haven't been edited since) are jumping around again. I saved & closed the file and then upon opening the PLN the next time, I opened with the repair option and overwrote the previous PLN with the repaired PLN. Some of the dimensions also jumped around in the repaired PLN. Only after opening each layout, selecting the drawing and then clicking "refresh" was I able to publish a PDF without dimension issues. This is unacceptable.
Please let me know if you have any other suggestions or if you would like me to send in a PLA for evaluation.
Thanks Minh.
Jeff
