Document Options Help
tannerosaurusrex
I am working in a teamworks file and use the publisher to create the pdf's of my drawings. I recently switched to Archicad on a pc and noticed every time I publish, it publishes every layout in the file. When I select document options it is not allowing me to change the source to "Selected Layouts in Navigator". Can anyone assist me with this?
1 REPLY 1
ryejuan
you need to check your role configurations if i'm not wrong.
In the end what is your Objective?
ArchiCAD 9 onwards
