Document & Visualize forum
Door Schedule Wall Thickness
EH21
Does anybody know why the "wall thickness" in my door schedule is rounding up to 4" and 6" instead of showing up as 3 1/2" and 5 1/2"? My dimensioning settings are all set to round to nearest 1/8". Or, is there a better way to indicate jamb depth for doors? I noticed that when I add a column for "Nominal W x H x T size," it accurately shows 3 1/2" and 5 1/2". However, I want jamb depth/wall thickness to be its own column.
Thanks for any feedback you might have. Screen Shot 2021-10-11 at 1.35.16 PM.png
Check also your 'Calculation Units' and if that is not it try 'Working Units'.
Versions 6.5 to 25
Versions 6.5 to 25
EH21:
Make sure your schedule is a View, and that View has its Dimensioning set to the correct Dimensions Preference.
You should add a Signature to your Profile (click the Profile button near the top of this page) with your Archicad version and operating system (see mine for an example) for more accurate help in this forum.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC24 USA • iMac 27" 4.0GHz Quad-core i7 | 24 gb ram • MacBook Pro 2.8GHz | 16 gb ram • OSX10.14.6
Steve Jepson
It might make very little differnece but I like to make my doors 4 9/16" or 5 9/16" since that is the size of door jambs sold in this area of the world.  I still make the walls with the framing/core as 3 1/2" and 5 1/2" since that is the nominal dimension.  It does not show up on the Plans, but it does let me show show the correct widths to order the jambs in the Interactive Schedules. And the reasons for that are related to how the Interactive Schedules are exorted as Excel file.   Just a thought you might be interested in.  The point of the Interactive Schedules I make are for the sake of ordering the materials.   Using nominal dimensions for walls is ok so long as you are consistant about dimensioning face to face or center to center where it counts.
ArchiCAD 25 4013 USA - Windows 10 Pro 64x - Dell 7720 64 GB 2400MHz ECC - Xeon E3 1535M v6 4.20GHz - (2) 1TB M.2 PCIe Class 50 SSD's - 17.3" UHD IPS (3840x2160) - Nvidia Quadro P5000 16GB GDDR5 - Maxwell Studio/Render 5.2.1.49- Multilight 2 - Adobe Acrobat Pro
