Door/Window Markers in Elevation!
Anyway you can turn on your window and door markers for your Elevations??
25 REPLIES 25
Erika Epstein
1. First open an elevation.
2. Select all the windows (activate the window tool &select all ctrl/cmd+A)
3. IN the info box or the Label & Listing Tab of the Window setting box check the Label Object box.
4. deselect the windows and activate the Label Tool. Select all the labels that appeared one on each window.
5. change the label type to Window Marker and then edit the settings so it looks like you want it.
6. Be sure to check the "Use Label'S Arrow' because the arrow for the window marker is to NOT have and arrow.
7. Note that in the window label you can have it read the ID box. I suggst using this as you can quickly fill in the door/window ID in your Info Box.
Do the same for doors and then repeat for each elevation.
HTH
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Stress Co_
Has anyone come across this:
Window makers work correctly on North and South elevations... But not on the East and West. The Marker cannot be rotated to read horizontally.
As you can see in the screen shot...in one case the preview is correct, but it's still rotated on the elevation.
Marc Corney, Architect
Red Canoe Architecture, P. A.
Mac OS 10.15.7 (Catalina) //// Mac OS 14.2.1 (Sonoma)
aahatimo
Every time I need to show call outs for doors and windows!
I am sure it's fixed in v16...... Right?
tim hanagan
aaha! design studio durango, co
27" retina 5k iMac 4ghz i7 os 10.13.6 m395x 4 mb, 32gb ram, 512 gb ssd ac 22 current
15" retina mbp 2.6ghz 1mb 16gb ac 22 current[/size]
Yup. Cannot understand why this never gets fixed...
K
One of the forum moderators
NCornia
I will report this and see about getting this fixed.
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
Stress Co_
Still not working correctly in AC16
NCornia
At the time I reported this AC16 was going into final compiling. The bug is in the queue though, so look for a future update to fix the trouble.
Best regards,
Nicholas Cornia
ARCHICAD on Twitter
Tutorials
Stress Co_
Thank you Nicholas.
For looking into the bug and ... your presence on this forum.
