Door/Window Markers in Elevation!
Anyway you can turn on your window and door markers for your Elevations??
25 REPLIES 25
Erika wrote:
1. First open an elevation.
2. Select all the windows (activate the window tool &select all ctrl/cmd+A)
3. IN the info box or the Label & Listing Tab of the Window setting box check the Label Object box.
4. deselect the windows and activate the Label Tool. Select all the labels that appeared one on each window.
5. change the label type to Window Marker and then edit the settings so it looks like you want it.
6. Be sure to check the "Use Label'S Arrow' because the arrow for the window marker is to NOT have and arrow.
7. Note that in the window label you can have it read the ID box. I suggst using this as you can quickly fill in the door/window ID in your Info Box.
Do the same for doors and then repeat for each elevation.
HTH
Stress Co_
NCornia wrote:
At the time I reported this AC16 was going into final compiling. The bug is in the queue though, so look for a future update to fix the trouble.
Seems to work now in AC17
Thanks Nicholas
Marc Corney, Architect
Red Canoe Architecture, P. A.
Mac OS 10.15.7 (Catalina) //// Mac OS 14.2.1 (Sonoma)
HTH
Hi, I've tried following Erika's advice above. I get stuck at point 5. 'Window Marker' isn't an option I can choose in the drop down box.
Nor is door marker for that matter.
Am I missing something????
Am I meant to load it from the 'load other label' ??
All advice appreciated.
Tom
Stress Co_
Do you see this?:
Gus
I can't for the life of me get window and door markers to show up on elevations even following the directions listed above. Any clues as to what I might be doing wrong?
I would like them to show up on plans and in elevations. Is this possible?
www.michaelgustavson.com Architect NY WI IL
Madison WI
Archicad21 MEP EcoDesSTAR Win10-64-bit
EliteBook8570W Corei7-3630QM@2.40GHz
QuadroK2000m RAM32 (2)250GBSSDs
4 Monitors Internet:4Up60Down
Stress Co_
Just a guess…
but go: Document> Layers> Show all layers.
Can you see the label now?
Link
Seems like there may be a little glitch there.
1. Try selecting a window in the plan view and enable the label there.
2. Then select the same window in elevation and enable the label there also. It should show up.
3. Then you can go back to the floor plan and turn off the label.
4. The label will still appear in elevation and all subsequent labels should show up in elevation without the need to show them in plan first.
Let us know if this works.
Link.
Brad Elliott
Thanks Nicholas
I'm using the latest version of 17 and still have the bug. Any suggestions?
Mac OS12.6 AC26 USA Silicon
M1 Macbook Pro
Brad Elliott
And it still won't put it in upright.
M1 Macbook Pro
aahatimo
maybe gs will figure this out, by release 27...
tim hanagan
aaha! design studio durango, co
27" retina 5k iMac 4ghz i7 os 10.13.6 m395x 4 mb, 32gb ram, 512 gb ssd ac 22 current
15" retina mbp 2.6ghz 1mb 16gb ac 22 current[/size]
