Find the next step in your career as a Graphisoft Certified BIM Manager!
Project data & BIM
Doors that are part of the Curtain Wall System are not showing in the door schedule
Gisele
The panel of a curtain wall system has a CW Double Door type; (see attached screenshots). How to add this door type to the door schedule?
AC 26 - 5002 USA FULL
Win11 Pro 22H2 - 13th Gen Intel(R) Core(TM) i9-13900KF 3.00 GHz - 64 GB - 64-bit operating system, x64-based processor
3 ACCEPTED SOLUTIONS
BrunoH
add a first line to your schedule criteria "Element type is panel OR"
ArchiCad 3.43 to 26
MacOS Monterey
Gisele
Thank you, Bruno.
It's because unlike doors placed in walls withe the door tool it's a 3D projection not a symbolic one.
If you want the door panel open set the 3D opening angle options to 90°.
If you want to see the opening lines you'll have to draw them manually.
Select the schedule cell then clic the annotate button and draw the lines
ArchiCad 3.43 to 26
MacOS Monterey
BrunoH
ArchiCad 3.43 to 26
MacOS Monterey
Gisele
Thank you, Bruno.
ArchiCad 3.43 to 26
MacOS Monterey
