2022-11-28 05:34 PM
Hello
When I drag a view on a new sheet, the name of that view is always some random location and the text is always window sill. I am sure i did change it once but not sure how that got saved. Is there a way to reset all that?
Solved! Go to Solution.
2022-11-28 07:12 PM
Open the settings for the Drawing Tool and check the Title and relevant settings.
Ling.
https://community.Graphisoft.com/t5/What-s-new/Creating-a-Thread/td-p/361315
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win10 | R5 2600 | 16GB | GTX1660 |
2022-11-28 11:21 PM
I am not sure if there is a way to reset but my workaround is to use the 'pick perimeter' tool (Alt+click) and that would become your default Drawing settings.
Just be sure that your Drawing Settings are set-up the way you want it. I think your setting should be like the one shown in the screen-cap below.
Hope this helps!
2022-12-01 07:00 PM
I knew it was something simple, hat setting was changed, thank you 🙂
2022-12-02 03:03 AM
The quick way to reset the ID & Name values to default is to go into the Drawing Manager, select the Views you want to change and the click on Settings at the bottom of the dialog window.
