Drawing Scale in the Master Layout template
Dalius
If you place drawing and interactive schedule onto the same layout, autotext of the drawing scale shows two scales in the template, eg. 1:100 (drawing scale) and 1:1 (schedule scale).
Is it possible to eliminate schedule scale?
Dalius Regelskis
AC user since version 6.0
http://archicad-pamokos.lt
Link
Not AFAIK. You can show the scale in each drawing's title instead and simple remove the title for the schedule, or you could use a white fill in your master or layout to cover the 1:1 scale.
Link.
Link.
Yes that is the only option I have found.
Jim
