Document & Visualize forum
Drawing use in photoshop
Does anyone know of a way to save plans or elevations to high resolution format that can be used in photoshop?
Everything I save as results in a very low quality image.
5 REPLIES 5
aahatimo
are there any advantages to saving a 3d view as a *.psd (photoshop) file? where would one use this ,psd file type?
tim hanagan
aaha! design studio durango, co
27" retina 5k iMac 4ghz i7 os 10.13.6 m395x 4 mb, 32gb ram, 512 gb ssd ac 22 current
15" retina mbp 2.6ghz 1mb 16gb ac 22 current[/size]
My PDF tip got moved to the Tips & Tricks section. (Thanks for considering it 'worthy', Djordje. 😉)
Readers of this thread, see:
http://archicad-talk.graphisoft.com/viewtopic.php?p=2179#2179
One of the forum moderators   •   AC 26 USA and earlier   •   macOS Ventura 13.2.1, iMac Pro 10-Core, Radeon Pro Vega 64
Djordje
Mentor
The PlotMaker will go there, too
Hint: no need to send your favourite tips to techtip@graphisoft.hu any more, the Tips of the month (still on!) are being chosen from the Tips&tricks forum.
So, if there IS a tip that I missed and you consider worthy, please send me a private message on the Forum (NOT the email!)
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Djordje
Mentor
MichaelRensing wrote:
3 easy steps.
Step 1: save view/plan/elevation as a .pmk file.
Step 2: open .pmk in PlotMaker and from there save as .eps format.
Step 3: open in Photoshop (these also open in Illustrator as vector files)
Moved to Tips&Tricks.
Djordje
HP Omen
I've used this technique for quite some time with great success. I like to create eps files and then make documents in a page layout program such as Adobe InDesign.
However, since this latest upgrade the fonts are not carrying through to the eps file. I get an error message when saving in PlotMaker saying that the fonts are missing.
I've tried several fonts, they are there in ArchiCAD when I create the drawing, they are available in InDesign but PlotMaker seems to miss them. Any thoughts?
