Document & Visualize forum
ELEVATIONS: SHADOW POLYGON FILLS (CAN THEY BE TRANSPARENT?)
Hey ArchiCAD community. I've got a problem with how archicad 23 illustrates shadows in elevations. When you enable shadows it places a solid fill over your surfaces. I'd prefer if it was transparent so that the surface can be seen. When you go into elevation settings, you will find under Model Display > shadow polygons. I don't see an option to make this transparent. Does anyone have a solution? I'd rather not have to turn off shadows and then draw a 2D fill as a shadow.
4 REPLIES 4
runxel
Ace
Just make the background fill pen transparent (="0") ?!
Mostly AC 26 on Mac | Author of SelfGDL | Developer of the GDL plugin for Sublime Text |
DGSketcher
Champion
AND the Shadow Polygon fill to "Background" or "25%"
Apple iMac macOS Monterey / AC26UKI (most recent builds)
Steve Jepson
I would add a word of caution. You may get a very different result for shadows than what you see on your screen if you Publish a .pdf using ArchiCAD than if you Print a .pdf using the Adobe Acrobat.
ArchiCAD 25 5010 USA - Windows 10 Pro 64x - Dell 7720 64 GB 2400MHz ECC - Xeon E3 1535M v6 4.20GHz - (2) 1TB M.2 PCIe Class 50 SSD's - 17.3" UHD IPS (3840x2160) - Nvidia Quadro P5000 16GB GDDR5 - Maxwell Studio/Render 5.2.1.49- Multilight 2 - Adobe Acrobat Pro
I tried that plus the other suggestion about using a different fill with a % less than 100 and it worked! Thanks
