2022-08-27 09:30 AM
Hello, I've never had this happen before within my settings for my elevation marker as I'm trying to highlight the extension lines for my elevations & sections markers on the floorplans.
I've tested out using other markers to see if the settings would change but still has the same settings as shown by the screenshots. Also I have the view options on for the marker range.
Currently using Archicad 25, Would just like a simple line showings its range on the floorplan without needing to manually draw one.
Solved! Go to Solution.
2022-08-27 09:46 AM
That’s a weird one. I don’t think Elevation Markers have extension lines as part of the marker other than the on screen view option which displays them to show the extent of the elevation. You’ve said that’s turned on? It isn’t something as simple as the pen for the marker range in your work environment is set to be white or even transparent if that’s possible?
2022-08-27 10:01 AM
I apologize, the section marker does have the option to show lines but not elevations.
I've realized that the elevations don't generally show a elevation line on the floorplan for presentation.
Thank you for the response and for opening the solution for me.
