Your question is a little confusing. You said "AC 24 out of the box" which I changed to AC24 USA in the subject line... since the USA version may be related to the issue... but the layout sheet you show is not part of the USA template... and so is not "out of the box". (The OOTB settings for any version of AC is the standard template [including all attributes] and the delivered Work Environment.)
One elevation is selected, so the green there makes sense. But, the other elevations showing green without selection dots is indeed strange. Does this happen on any other layouts with other kinds of views/drawings? Did it suddenly start happening today?
Also... your signature shows AC 22/23 but your obviously on 24 now. It also shows Windows 7 and Mavericks, neither of which is supported by AC 24... so I assume this is Windows 10 since your screenshot is a Windows one?
What build of AC24 are you running?
Edit/PS: I've merged your other post about the green appearance to here. One thread about this strange green appearance is enough. Hope someone has an idea for you - I'm drawing a blank right now.
One of the forum moderators
AC 27 USA and earlier • macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
