Elevation lines disappears in layout
I have made a drawing in floorplan with elevations. The elevationlines shows on this drawing. I copy the drawing to the layout. In the layout, the elevationlines has disappeared. The attached file illustrate this problem.
Please help!
6 REPLIES 6
David Maudlin
Anne:
You did not post a screen shot of the floor plan, so I will guess that the lines you are referring to are the Marker Range lines, which are on screen only (do not print). You can check this by looking at View > On-Screen View Options > Marker Range.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
You are absolutely right, David! When I switched the marker range off, they also disappeared in the floorplan. How do I get them permanently?
I tried to post such a screenshot, but it seemed like I could not post more than one attachement at a time.
Eduardo Rolon
Try these settings
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Is the screenshot from the elevation settings?
I attach what I get in version 16 in the elevation settings.
Eduardo Rolon
Nope, that is why I use the Section Tool when doing Interior Elevations.
AC27 US/INT -> AC08
another Moderator
Thank you. I'll do the same as you.
