2021-08-21 03:32 AM
Solved! Go to Solution.
2021-08-21 04:29 AM
2021-08-21 04:29 AM
2021-08-21 06:33 AM
2021-08-21 09:43 AM
2021-11-13 01:22 AM
Hi again,
Last time I thought that I did it or maybe now I am doing something wrong. The problem that I am having now is how to apply 'Graphic Override' only to walls, slabs and other stuff that are 'As built to sanction'. Because when I am applying the Graphic override, all stuff are changing colors not only walls that are 'As built to sanction'.
In other words I want to select 'Graphic Override' for only 'As built to sanction' walls and only those walls turn into blue and not all walls.
2021-11-14 04:48 PM
You have to set the criteria to filter for the elements you want to affect.
2021-11-15 12:28 AM
Hi Barry Kelly thanks for your reply. Yes I changed Element type to Wall and it's OK. But how can I apply only to 1 or 2 walls instead of all walls? Because like this all walls are changing colour.
2021-11-15 12:48 AM
You need to set the criteria so it searches only for those walls that you want to override.
So with the 2 criteria as shown in you image (Element type is wall and Renovation status is As Built to Sanction) that should only select walls with that particular renovation status.
You can add more criteria to include/exclude certain elements.
The criteria filters in or out the elements you want to override.
2021-08-22 01:33 AM
2021-08-22 03:54 AM
2021-08-22 06:42 AM
insideru wrote:Yes I agree with you.
but i prefer to stick to layers to order elements (interior/exterior walls, slabs, etc)
