Dave's method always works and worked around a bug in the Artlantis exporter from some versions ago. If you have a relatively recent version of ArchiCAD, you can specify the reference file in the export dialog from ArchiCAD itself. When you open your file in Artlantis, all prior material assignments, object placement, camera positioning, etc will be present in the updated model file.
One of the forum moderators
AC 27 USA and earlier • macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
