Document & Visualize forum
Exporting publisher
In organizer I have transferred my layouts from layout book to publisher sets, saved as a single file and published. I can't find a way to get the file out of Archicad so I can email it to my printer. In the past I've resorted to taking my on screen single layout and "saved as" a pdf, named it and transferred it to a dedicated desktop folder. I know this is a primitive method and am certain I'm missing something obvious. Please help. Thanks-Dave
Dave:
In the Navigator, when you select the Publisher Set (which should contain the Layouts set to PDF file format), click the Publishing Properties... button, in this dialog box you set the Path where the PDF file is published. Once published, e-mail the file to your printer.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC26 USA • iMac 27" 4.0GHz Quad-core i7 | 24 gb ram • MacBook Pro 2.8GHz | 16 gb ram • OSX10.15.7
Dave:
David
Thank you.
