Exporting to ifc - Wall healing issues
Arcadia
I have a builder client that needs .ifc files for a virtual colour selection service they are using. The exports are mostly fine with one big issue - the walls don't heal properly like they do in Archicad. Most of the walls intersect as though they are just overlapping not intersecting though weirdly some do heal properly even though they are identical intersections in AC. Screenshot from a ifc viewer below
Any ideas how to fix this?
V12-V27, PC: Ryzen 9 3950X, 64g RAM, RTX5000, Win 11
I would check that the geometry export is set to BREP. That should fix the issues you are facing.
Nathan Hildebrandt fraia
Director | Skewed
AC6 - AC27 | WIN 11 | i9-10900K, 3.7Ghz | 32GB Ram | NVIDIA GeForce RTX
3070
Director | Skewed
3070
Thank you so much I found where I could set this and it totally worked.
