It is the only one you didn't try - dimensions.
Be sure though to save is as the scheme you are using (saved with your view settings), otherwise you will find it reverts back.
I wish it had a "Redefine" button rather than the "Store As" so you don't have to type the scheme name in yourself.
TIP. Rename the scheme and copy the name (then cancel and don't actually rename anything).
Make your change then Store As and paste the name.
