Fill area - accuracy
Hello everyone:
So i use fills sometimes to calculate areas.
The problem im having is that i want it to calculate areas with 2 decimals accuracy, not 3 or more, it seems the program sometimes its rounding the digits to close values.
example: 2 x 2.234 = 4.468 = 4.46m2 not 4.47m2.
Regards.
1 REPLY 1
This is basic mathematics and ARCHICAD is calculating it correctly, using. Your example:
2 x 2.234 = 4.468 which then rounds to 4.47
What you are wanting (4.46) is an incorrect result.
Scott
