Document & Visualize forum
Fill scale is not same on layout and plan
Greetings !
I'm relatively new to Archicad, suppose it might be simple solution. I want to have fill as dense as 1:20 but scale of wall fills are different though I have set both plan and layout scales to 1:20, as demonstrated on image.
Hi Jan,
Check on your Fill definitions for "Scale with plan" or "Scale Independent".
More information here: https://helpcenter.graphisoft.com/user-guide/77001/
Hi Jan,
That was exactly what I was looking for, thank you!
Labels
