2022-01-18 03:57 AM - last edited on 2023-05-09 06:09 PM by Gordana Radonic
Am I going crazy, or is there really no way to select fills according to fill pattern, using the find and select dialog?
This is on Archicad 23 (sadly the firms I freelance to tend to stay 2 versions behind), and for the life of me, I am not finding it. Fill pattern is the one characteristic that most visibly distinguishes any given fill from another, and very often all other fill parameters are the same in a view with lots of placed fills
Solved! Go to Solution.
2022-01-18 04:06 AM
here is a screenshot where you can find the pattern.
2022-01-18 04:06 AM
2022-01-18 04:09 AM
OK, to answer my own question, yes I am going crazy. Just click to add the 'Fill' attribute, then select fill pattern from the sub menu that appears.
Possibly a UI language translation error - 'Fill' here is not referring to the element type, but to the fill pattern in this context.
2022-01-18 04:13 AM
but still "Fill" itself is an element type... and yes maybe the way they label the "Fill" in the sub menu instead of fill pattern. 🤔
