Find and Select: fill pattern parameter missing?
Paul King
Am I going crazy, or is there really no way to select fills according to fill pattern, using the find and select dialog?
This is on Archicad 23 (sadly the firms I freelance to tend to stay 2 versions behind), and for the life of me, I am not finding it.  Fill pattern is the one characteristic that most visibly distinguishes any given fill from another, and very often all other fill parameters are the same in a view with lots of placed fills
PAUL KING | https://www.prime.net.nz
ArchiCAD 8-27 | Twinmotion 2023
Windoze 11 PC | Intel Core i9 10900K | Nvidia Gforce RTX 3080 | 32 Gb DDR3 | 2x4K monitor extended desktop
ryejuan
here is a screenshot where you can find the pattern.
In the end what is your Objective?
ArchiCAD 9 onwards
ryejuan
ArchiCAD 9 onwards
Paul King
OK, to answer my own question, yes I am going crazy.  Just click to add the 'Fill' attribute, then select fill pattern from the sub menu that appears.
Possibly a UI language translation error - 'Fill' here is not referring to the element type, but to the fill pattern in this context.
but still "Fill" itself is an element type... and yes maybe the way they label the "Fill" in the sub menu instead of fill pattern. 🤔
ArchiCAD 9 onwards
