Document & Visualize forum
Finish Schedule - Older Method
Red
First off, I'm not too fond of a finish schedule like this, but I can not get him to adapt, in my opinion, the more modern way of showing it. I feel this style of finish schedule could cause a person to misread a finish, or even me to mess up drawing it. Can this style be achieved with the Archicad schedule? Possibly with it showing an "X" or checkmark in the column? I can not think of a method with Archicad scheduling doing this, but I thought I would ask before spending the time to draw it manually.
Thanks,
Red
i7 8700k
ROG Strix Z390-E MoBo
64gb RAM
EVGA GeForce GTX 2080
_______________________
http://www.facebook.com/flatcreekdesignstn
http://www.sraarchitects.biz
Lukas Zeleny
Hi Red, if I understand it right I have a solution for you for those dots. Create properties named: Carpet, V.C.T, Concrete sealed... and so on with data type = Option set. Create two (or more) options with "dot" sign and !spacebar" or other chracter from Chracter map. Aply those properties to your rooms.
Then you can create schedules with dots (in my case with walls).
But this solution has its dark side, you have to create new property for each finish.
And also creating shedule as in your picture is probably impossible because of the first line dividing the elements by type.
I woul rather suggest to export Excel schedules from Archicad with all needed parameters and try to a clean them up in Excely through formulas and macros. But only if this is repetitive task because it will take lot of effort to doit.
BIM Manager at SIEBERT+TALAŠ
www.sieberttalas.com
That is an excellent thought and idea. If I am still forced to go in that direction, I will use this method. I am still trying to get my boss to adjust to the easier/quicker solution. However, the generation gap from his career to mine continues to be a struggle, and understandably so... It happens to each generation, I feel, LOL
Thanks,
Red
i7 8700k
64gb RAM
I dont have any answers but i am so sorry that you have to do this... so illogical to me too...
good luck
FREE wall Accessory framing and coverings - bit.ly/BIMRithmWallAccessories
FREE Truss object - https://bit.ly/BIMRithmTrussV1
FREE Custom Tube Object - https://bit.ly/BIMRithmPolyTube
AC 24, Twinmotion current, Windows 11, Msi 10UG with rtx 3070, wacom intuos pro m, Wacom Cintiq Pro 16, razer Tartarus pro.
Labels
