2022-09-20 07:34 PM
Hi all,
I'm struggling to figure out what i need to do for get the right appearance for a floor plan of mine.
On "ground floor" level the problem is that the contour lines of the ground mesh is visible through the wood deck - at least the ones that are beams, not the morphs for some reason.
On the "ground level" below the contours of the ground mesh are not visible through the wood deck.
I have tried with different floor plan displays but i can't find the issue why I reach out to the community.
I bet there is a simple fix to it...
Problem at the ground floor level:
Desired result where the contour lines are hidden by the wood deck but on the ground level beneath ground floor level:
Thanks in advise!
/André
2022-09-21 03:37 AM
Looks like your GO is turning off your Background Fill. From memory, morphs do not have a fill.
Ling.
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win10 | R5 2600 | 16GB | GTX1660 |
2022-09-23 10:55 AM
I still can't find a difference in floor plan display or different graphical overrides that could generate this "error".
2022-09-27 03:20 AM
The top image is your Ground Floor Plan, whilst the second is your Footing Plan? Your deck is a Slab? Is it's Home Story your footing plan? Check the slabs Floor Plan Display settings?
