Hi Laszio,
Sounds promising. I haven't tried anything like that yet and am not familiar with expressions in Archicad. Creating a new property was easy, but I can't seem to find any parameters or properties that seem to fit my objective. ie: In order for the expression to be relative to the view, I need a parameter that is specific to the view in order to establish the base point of the equation. ie: the equation needs to look something like this:
if [Element Vertical Position) is higher / greater than the [View Cut-Plane Vertical Position] = Above
if [Element Vertical Position) is lower / lesser than the [View Cut-Plane Vertical Position] = Below
Alternatively I could work with something like this instead:
if [Element Home Story) is higher / greater than the [View Home Story] = Above
if [Element Home Story) is equal to or lower / lesser than the [View Story] = Below
Then, in either case I would need a graphic override with ta rule that would filter elements based on the returned value of 'Above' or 'Below'.
It looks like the list of parameters is entirely related to elements. I see properties in the list that relate to the 'Element Home Story', and the 'Element Vertical Position' variables listed in my expressions above, but I don't see a single parameter that appears to be targeted at the properties of the view. Can you help me with that?
Jeff G
Archicad 23 USA (full), Macbook Pro (16-inch 2019)
