Graphic override - associative dimensions and labels
It would be great to highlight labels that are associative/ independent and similarly dimensions that are static or have become disconnected.
This wish is connected somewhat to our detailing of mods, patches, annotation overlays where it's helpful to quickly audit a view to see what's accurate.
What I'm really looking for is what labels read element ID, and what dimensions are misplaced/ custom or broken.
Let me just post a screenshot of the solution to the first question.
So, it is possible to create a Graphic Override Rule, which would take of Dimension and Level Dimension type elements, the "Annotation State" of which is "Static". This means those Level Dimension elements the "Static Level" toggle of which is ON. It also means those Dimension elements the "Static Dimension" toggle of which is ON, and even those Dimension elements where you have selected one or more Dimension Points of a Dimension Chain and toggled the "Static Dimension" toggle ON only for those Dimension Points. So if at least one Dimension Point of a Dimension element is "Static", the criteria will be met.
The Override Rule in this example overrides the Pen of the whole Dimension to Red. The reason it overrides the whole Dimension element is because Graphic Overrides can only override whole elements, they cannot override only parts or individual Components of an element.
About the second wish: that would be great as well.
We would need another Criteria in the Graphic Override Criteria Panel. It should be called "Dimension Text" or similar, and its two possible states should be "Measured Value" or "Custom Text".
10 REPLIES 10
Eduardo Rolon
That can be done now for non-assoc Labels and Dims, the setting is "Annotation State"
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
runxel
Legend
Yeah thats nice, but what I would like to have is a criteria to select all dims that have a custom text! This is not available at the moment – causing some pain!
This is great! Thanks for the info.
These little checks make my life so much easier.
Best of luck on the second point.
Yes, that is a wish, because currently it is not possible to do, there is no Graphic Override Rule criterion for it.
Minh Nguyen
Hi All,
I hope you are doing well in these trying times!
Thank you very much for sharing your wish!
I am happy to say we took notice of this wish and I have added it into our WishList database (please refer to it as Wish #12714). Hopefully, our Product Management team will adopt this one in the future.
Thank you all once more, and I wish you a great day!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
Stress Co_
Workaround.
As a rule. When I change a dimension from "measured" to "custom",
I also change the text pen to one which is Red in my View pen set
and black in Layout pen set.
I can always see which dimensions are custom.
Marc Corney, Architect
Red Canoe Architecture, P. A.
Mac OS 10.15.7 (Catalina) //// Mac OS 14.2.1 (Sonoma)
Sounds a lot more friendly than banning custom or static dimensions with the threat of cutting people's fingers off.
Eduardo Rolon
Actually no.
Finger cutting is a lot less stressful.
AC27 US/INT -> AC08
another Moderator
