Grid Tool Problems
My grid elements are acting funny in section/elevation. Instead of the grid lines and marker heads being straight up and down all the marker heads are offset to one side. They are all offset the same amount and in the same direction.
So I go into the settings everything looks right, I manually put the marker heads back where i want, save current view, but every time I come back to the view the grid elements have offset themselves again.
I'll attach some image of a view and the settings dialog box in a minute.
Thanks.
Is this a teamwork file? If so it has been reported to Graphisoft as a bug. Saving it as a pln corrects the issue.
eureka!!! thanks that fixed it.
