Document & Visualize forum
HOW TO SAVE TEXT SETTINGS FOR THE LEVEL DIMENSION TOOL?
4hotshoes
I want th level dim tool to show in reference to sea level. I can manually change the Autotext to do that, but I cannot figure out how to make it the standard for every time I use it. It seems as though the symbol and text are separate when saving them as a favorite or copying parameters. I do not want to have to manually change the text to read the sea level height of the mesh for every time I place the Level Dimension marker.
Todd Oeftger
Ligature Studio
AC23 and AC24 Mac MacBook Pro 15", 2019, 2.3 GHz i9, 32GB, Radeon Pro 560X 4GB, 500GB SSD, 32" Samsung Display (2560x1440)
4 REPLIES 4
Lingwisyer
Related post: https://community.graphisoft.com/t5/Wishes-forum/Level-Dimension-to-Reference-Level-sea-level/td-p/1...
No solution still...
AC18-23 AUS 7000
Self-taught, bend it till it breaks.
Win10 | E5620 x 2 | 24GB | K2200
Win10 | R5 2600 | 16GB | GTX1660
DGSketcher
@4hotshoes If it helps you can select the associated text values of multiple markers and rt-clk to edit the text values in one hit rather than editing each one.
Apple iMac macOS Big Sur / AC24UKI (most recent builds)
SwedishChef
Does it work if you save a Favorite?
DELL Precision 5560
i7-11850, 32 GB, RTX A2000
AC12 - future
Did you try it?
You will be disappointed.
The favourite saves the level dimension settings, but not the text content.
Versions 6.5 to 25
Labels
