Document & Visualize forum
HOW TO SAVE TEXT SETTINGS FOR THE LEVEL DIMENSION TOOL?
4hotshoes
I want th level dim tool to show in reference to sea level. I can manually change the Autotext to do that, but I cannot figure out how to make it the standard for every time I use it. It seems as though the symbol and text are separate when saving them as a favorite or copying parameters. I do not want to have to manually change the text to read the sea level height of the mesh for every time I place the Level Dimension marker.
Todd Oeftger
AC25 Mac MacBook Pro 15", 2019, 2.3 GHz i9, 32GB, Radeon Pro 560X 4GB, 500GB SSD, 32" Samsung Display (2560x1440)
4 REPLIES 4
Legend
Related post: https://community.graphisoft.com/t5/Wishes-forum/Level-Dimension-to-Reference-Level-sea-level/td-p/1...
No solution still...
Win10 | R5 2600 | 16GB | GTX1660
DGSketcher
Champion
@4hotshoes If it helps you can select the associated text values of multiple markers and rt-clk to edit the text values in one hit rather than editing each one.
Apple iMac macOS Ventura / AC26UKI (most recent builds)
SwedishChef
Does it work if you save a Favorite?
DELL Precision 5570
i7-12700H, 64 GB, RTX A2000 [8GB]
AC12 - future
Did you try it?
You will be disappointed.
The favourite saves the level dimension settings, but not the text content.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
