Help with lines
I'm just wanting some help with line weights and publishing (it's been a while since I've used the program)
I've used polylines which looks okay in layout but when I publish you can see every single point, making the line look disjointed.
Does anyone know how to fix this?
Thanks!
Podolsky
Ace
I don't think it's ArchiCAD problem. It's a problem with PDF viewer you are using. I had similar after some upgrade of MacOS few years ago.
You can easily check it - paste your PDF somewhere in ArchiCAD and explode. If it shown OK - then this is PDF viewer. Try to use another one.
Podolsky
Ace
Omg Thankyou so much! I placed it into InDesign and exported as another pdf and it looks fine! Strange as they're both pdf files viewed through preview on Mac - there must be something different about the file straight from ArchiCAD.
Thanks again, you've saved me a lot of stress!
