Document & Visualize forum
Hotlinked module - Display order
Vincent G_
I got this typical floor module that I placed on the above levels. I got one slab I can't manage to place behind the hotlinked mod. I try to send it back but I got the message saying it's as far it can go. I've tried to turn all layers on, suspend group, select the mod and bring it on the front but it didn't work.
I assume this happens because there must be stuff in the mod that is sent back as well. Is there a solution in this case or do I have to spend an hour trying to fix the mod and re-link it?
The mod
The slab
I wish Graphisoft could implement a display order system the same way as material's intersection priority. You choose a number of display orders (1-10, 1-100 ...) and then define layers or/and items as per that display order value i.e every slab (or slab layer) in Display Order # 10, every floor finish D.O #15, all floor finishes tags DO#30 etc so you never have to struggle bringing stuff front and back for ever..
1 ACCEPTED SOLUTION
Solution
Hi @Vincent G_ ,
It will change depending on what you have selected but here is the element information for a fill, note that I only have the very left most content tab highlighted.
ArchiCAD 24 NZE FULL
Windows 10 Pro 1909
Intel Core i7-6700; 32GB RAM; AMD RX480
6 REPLIES 6
Labels
