2021-10-19 02:02 PM
There is no PAN button on the bottom of my AC24 screen. There used to be a 'hand' labelled button but it is no longer there.
I've now noticed this because I used to depress the scroll wheel on my mouse. But I've just got a new computer and a K4 screen, and am reusing my trusty mouse and the scroll wheel no longer works. Instead, when I press it to PAN, it flips my layout up to the top left of my screen, at 1/4 of its original size. Any ideas?
2021-10-20 12:40 PM
With my logitech mouse I use software called 'setpoint' to configure the buttons, as Barry pointed out.
However the wheel actually has several functions: scroll wheel, middle button and two 'side' buttons (left / right). I had to set the wheel to 'middle' button and turn off the 'left' and 'right' function of the wheel for it to behave.
Perhaps you have the same issue.
2021-10-21 03:55 AM
MS 5000 is a 5 button mouse, which I assume means it does not have tilt.
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win10 | R5 2600 | 16GB | GTX1660 |
2022-10-13 01:27 PM
Hi!
I am struggeling with a similar issue. My new computer (Lenovo), stupidly enough does not have that extra button (Pan button). It works when I use a logitech mouse, but sometimes I dont have that mouse with me.
THAT is when I miss the Pan-tool (the hand).
Did you figure out if it is possible to make a short cut or if the "hand" has returned ?
